Door always in the middle of the wall in 2D (can't change reveal)
jankubacka
I just found out that door reveal option does not correspond in 2D representation. It is always in the middle of the wall. In 3D, it is correct. I have no idea what I do wrong. In older version of course it works fine. Please, can someone try this?
Thanks!
Operating system used: Windows 28.0.0 (3001) CZE
If you look at this support article, I believe it’s the 4th button from the left under the Floor Plan detail option for the doors.
https://help.graphisoft.com/AC/28/INT/_AC28_Help/140_UserInterfaceDialogBoxes/140_UserInterfaceDialo...
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
I suspect it is a setting within Model View Options. Try looking there for any setting relating to displaying the revel in 2D. I haven’t got it open at the minute to say exactly where it is.
Lee Hankins
Lee Hankins
Thanks a lot! It is really hidden and I don't know why it is turned on in default template. Have a nice day.
Setup info provided by author
