Paul King
Mentor
Door and window number need to differ between otherwise identical module instances
I have a project where two adjacent multistory buildings are almost identical, that would make perfect sense as two placed instances of the same module, but that need door and window numbers that are unique to each building.
The building design will continue evolving, and it makes little sense to keep updating two separate buildings.
How can I get the door and window markers within modules to automatically display a different door or window number prefix depending on which placed module instance is involved in plans, elevations and schedules?
A further complication is they (crazily) occupy different constriction and documentation phases, so need to switch on or off accordingly in views, depending on which phase I am showing.  I am using design options as the nearest thing ArchiCAD seems to have to phasing control  that does not require massive duplication of layers.
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-29 | Twinmotion 2025
Windoze 11 PC | Intel Core Ultra 9 285K | Nvidia Gforce RTX 5090 | 64 GB | 2x4K monitor extended desktop
4 Replies 4
Do you use module id for something else?
Archicad 27 - GDL - PYTHON
Here is how to set the Master ID of the Hotlinked Module and the ID of Doors/Windows in the source file of the Hotlinked Module.
Paul King
Mentor
Thanks Laszlo - that got me quite excited for a moment, until I found that this option seems to be missing in CI Tools door and window markers (whole project uses CI Tools doors and windows)
Can you assign a Door/Window Marker from the Archicad default library to a CI Door/Window in the Dimension Marker panel?
