Drag view on layout
Foti
Hello
When I drag a view on a new sheet, the name of that view is always some random location and the text is always window sill. I am sure i did change it once but not sure how that got saved. Is there a way to reset all that?
undefined
Foti B.
AC25
PC Precison 5760, Xeon 11955, 64GB, Nvidia RTX A3000
2 ACCEPTED SOLUTIONS
danielleL
I am not sure if there is a way to reset but my workaround is to use the 'pick perimeter' tool (Alt+click) and that would become your default Drawing settings.
Just be sure that your Drawing Settings are set-up the way you want it. I think your setting should be like the one shown in the screen-cap below.
Hope this helps!
ArchiCAD 18-26 | Twinmotion 2022
Mac Mini (M1, 2020) | macOS Monterey | Apple M1
HP Victus | Windows 11 | 16.0 GB RAM | AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz
DGSketcher
Legend
The quick way to reset the ID & Name values to default is to go into the Drawing Manager, select the Views you want to change and the click on Settings at the bottom of the dialog window.
4 REPLIES 4
Lingwisyer
Guru
Open the settings for the Drawing Tool and check the Title and relevant settings.
Ling.
https://community.Graphisoft.com/t5/What-s-new/Creating-a-Thread/td-p/361315
danielleL
Hope this helps!
I knew it was something simple, hat setting was changed, thank you 🙂
Foti B.
AC25
DGSketcher
Legend
