Foti
Drag view on layout
Hello
When I drag a view on a new sheet, the name of that view is always some random location and the text is always window sill. I am sure i did change it once but not sure how that got saved. Is there a way to reset all that?
Foti B.
AC25
PC Precison 5760, Xeon 11955, 64GB, Nvidia RTX A3000
2 Solutions
danielleL
I am not sure if there is a way to reset but my workaround is to use the 'pick perimeter' tool (Alt+click) and that would become your default Drawing settings.
Just be sure that your Drawing Settings are set-up the way you want it. I think your setting should be like the one shown in the screen-cap below.
Hope this helps!
ArchiCAD 18-26 | Twinmotion 2022
Mac Mini (M1, 2020) | macOS Monterey | Apple M1
HP Victus | Windows 11 | 16.0 GB RAM | AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz
Go to post
DGSketcher
Legend
The quick way to reset the ID & Name values to default is to go into the Drawing Manager, select the Views you want to change and the click on Settings at the bottom of the dialog window.
Go to post
4 Replies 4
Lingwisyer
Guru
Open the settings for the Drawing Tool and check the Title and relevant settings.
Ling.
https://community.Graphisoft.com/t5/What-s-new/Creating-a-Thread/td-p/361315
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
danielleL
Hope this helps!
Foti
I knew it was something simple, hat setting was changed, thank you 🙂
Foti B.
AC25
DGSketcher
Legend
