RandyC
Drawing Titles
As all of my schedules have a built in Title - is it possible to have Drawing titles not show for these but
to show for all plans,sections elevations. etc.
Currently I have to remove titles manually from each schedule I place or Change to no title then I have to Add titles to anything I place in the future that needs a title.
Thanks, Randy
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
2 Replies 2
You can select all your views parameters into your layout without open any layout
By this way you can modify all views you have selected in one go
Maybe it's a good beginning 😕
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
RandyC
Hi Christophe,
Thanks for the input - I would like to set the view map to have the drawing titles on or off
there appears to be no setting -- you suggestion is probably the best I can do "after" I have set every drawing
to the Layout book . Kinda leaves things messy until I set them all at once like you suggest.
