Drawing moves when it's updated on the layout
recently I've been having some trouble when updating my drawings on layouts. When I update a drawing its view shifts from the position that it was placed on the layout. This displaces the drawing so its not enteirly visable anymore. This happens randomly and is frustrating because I have to always correct the layouts agin and again.
Additional info:
The drawings do not have "Use internal origin" ticked, and they are drawn on the viewport origin. I use AC version 24 build 3022.
Thank you for your help.
1 Solution
Lingwisyer
Guru
Set the View on the Layout to use the drawings internal origin?
Ling.
Go to post
3 Replies 3
Lingwisyer
Guru
Ling.
That did fix the issue. Thank you.
The problem still persists even when it is set to use internal anchor. It happened again when I moved some annotations to a difrent layer. When I updated the layout the drawing jumped again.
