Elevation marker lines
Strawbale23
Hi
Trying to find the setting to turn on the line between the marker heads.
I have turned it off or changed the colour, but cannot find the setting that controls this in the info box.
AC info box settings are a complete nightmare for finding settings. The layout is non
AC26
https://www.zendsign.fr/
Miha_M
Aaah, sorry, I understand now. I don't think you can have this line (for output) in between both marker heads with the built-in elevation marker.
However you can control the "virtual" visibility of this marker line through View > On-Screen View Options.
You can also adjust this color in the Work Environment UI:
| Archicad 4.55 - 27
10 REPLIES 10
Miha_M
Section Selection Setting > Story Levels
and
...if you need to have these lines in your published docs.
| Archicad 4.55 - 27
Hi thanks you. I  am however refering to the marker lines on plan view, between the marker heads
Thanks
AC26
Miha_M
Sorry, the thread title mentions elevation. Which elevation marker lines on plan view, could you make a screenshot of this marker head?
| Archicad 4.55 - 27
Sorry, I ment the elevation marker on plan view, which I want to show the line of the elevation across the plan, similar to the section marker.
AC26
Miha_M
| Archicad 4.55 - 27
There are other elevation markers in other localization libraries which have extandable lines at the marker head, but I haven't seen any on which one could turn on/off the middle segment like in my previous elevation marker post.
| Archicad 4.55 - 27
Ah Ok, thanks. I had a memory of markers lines being possible for elevation markers on plan view.
Thanks for your help!
AC26
I don't have Archicad running at the moment, but I think with elevations, there is an option for 2 marker heads and then they act like the sections.
Miha_M
There is the option with two marker heads, but there is no option for a line connecting the marker heads. However a section marker could be used for the same purpose.
| Archicad 4.55 - 27
