Elevations: Show colours through transparent surface?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-07-02
01:43 PM
‎2023-05-23
03:03 AM
Gordana Radonic
I have an elevation with a glass window, transparency switched on, can see through all ok. However nothing comes through in colour - its all hidden line?
When I remove the glass, or any surface that is transparent, colour is visible. Example attached.
The material is switched to full transparency, the vectorial hatching set to Empty Fill, and the elevation settings have cut surfaces in colour, transparency on etc.
Appreciate any help!
Thanks
JG
- Labels:
Elevations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-02 03:15 PM
There is a workaround: You have to set the glass material to be fully transparent. A full 100%.
One caveat tho: in 3D ... well, it will be kind of invisible now. However, if you set a vectorial fill for the material with a fixed pen, it will give you really neat looking sections/elevations, where the colors are blending just like you would expect.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-02 04:12 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-02 11:35 PM
Surely Archicad allows for colour transparency?
JG
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-02 11:40 PM
JG
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-03 12:45 AM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-03 01:27 AM
grejxx wrote:Did you tried what I wrote? It's definitely working. 🙂
Yeah I just want glass or any 100% transparency to show objects that are located behind in colour. Doesnt seem to work in any method.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-03 01:44 AM
Did you try what I wrote? It's definitely working.![]()
Yes, see my settings. All the same - still grey / hidden line?
I can use any glass/material with wall/slab/object and it is all the same.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-03 08:55 AM
grejxx wrote:It's because your 25% vectorial hatch is obscuring anything behind it. Should change to a background or airspace fill.
I can use any glass / material with wall / slab / object and its all the same
Graphisoft Senior Product Manager
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-03 09:07 AM
James wrote:Thanks, i've tried airspace, background, empty fill etc...eg attached
