‎2010-08-11
06:15 PM
‎2023-05-19
10:16 PM
Gordana Radonic
‎2010-08-12 12:31 AM
Steve wrote:This is how you can be sure what the Publisher is using to generate the .pdf's
.... I tried toand publishwith different .pdf settings. Ellipse seems to work fine with any scale sensitivity setting. I also tried printingfrom the floor plan and from the layout.
‎2010-08-12 05:06 PM
‎2010-08-12 05:20 PM
‎2010-08-12 05:31 PM
‎2010-08-12 11:27 PM
‎2010-08-14 03:06 PM
Erika wrote:But you're using Mac I assume. Looks like a PDF print driver problem.
I can't duplicate the problem. Just published this from 14.
‎2010-08-14 04:06 PM
‎2010-08-15 09:25 PM
Erika wrote:Who knows? Definitely odd. Remarkable that you managed to narrow it down so precisely.
Matthew,
I tried on a pc that matches his specs. I can reproduce the problem
only with mirrored instances AND when in TW2.
Is that a print driver problem?
‎2011-02-28 08:53 AM
‎2011-03-07 01:54 AM
