ā2014-11-06
04:52 AM
ā2025-02-06
12:19 PM
Aruzhan Ilaikova
ā2014-11-06 06:57 AM
ā2014-11-06 03:23 PM
ā2018-04-19 04:19 PM
ā2018-04-20 07:54 AM
Erich wrote:I use the Erich Method.
I work slightly differently than Barry.
I use specific layers for annotation for specific purposes (floor plan, reflected ceiling,electrical, structural, etc.) So if I need an enlarged plan, I will have a layer for those notes separate from any others. Then I will set up a view at the enlarged scale that uses the layer combination that includes the notes for the enlarged plan.
This view can then be placed on a layout and cropped as necessary. Back in your main floor plan, I would then place a linked detail bubble that references the previously placed enlarged plan.
This way, you have a completely live enlarged plan that is easy to work on and is nicely referenced in your drawing set.
ā2018-04-20 01:09 PM
dcerezo wrote:Hi, using archicad for quite some time (since 2006). We have our model related output up to 1:50 scale, with very little 2D patching needed. 99% of 2D work there is annotation. We do use complex profiled walls / beams a lot to get connection details to show nicely in a 1:50 detail setting.
We are relatively new to ArchiCAD, having come over from Revit, but this issue with Enlarged Plans and Details is really making us regret making the switch. The time it takes to do unit plans, enlarged bathroom and kitchen plans, enlarged stair plans, and corresponding annotations is insane.
What used to take us maybe 5 min tops, per unit plan, in Revit, is taking us like an hour in ArchiCAD because we have to create this layer or that, shut that one off, create a layer combination for this...it's ridiculous.
My question to all of those folks who have been using ArchiCAD for a long time is....really...is there no easier way?
ā2018-04-20 08:42 PM
alemanda wrote:I do, too. I don't see how this method would take even the 5 minutes that Revit would.
ā2018-04-22 06:12 AM
ā2018-04-22 06:41 PM
ā2018-04-22 10:04 PM
