dhnguyen
Fills
I accidentally purged all default fills. How and where do I reload the default fills into my file again?
I tried to do search on this topic, found some answers but wasn't able to do it on my own.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
1 Solution
Eduardo Rolon
Open the File with the missing Fills then in Attribute Manager
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
4 Replies 4
Eduardo Rolon
You will need to use Attribute Manager (under options) to import them from another file. Try bringing them using Index Number.
AC29 US/INT -> AC08
dhnguyen
This is where I got stuck. I opened a standard file, saved the attribute. Then now I opened my file and in "Attribute Manager", I clicked on the "Open" button to load the .aat file but it doesn't work.
DNguyen
ArchiCAD 18- 25
Eduardo Rolon
AC29 US/INT -> AC08
dhnguyen
Thank you, got it now!
DNguyen
ArchiCAD 18- 25
