Fills
My solid colored fills in my floor plan have mysteriously become transparent.
I have experimented with changing the model view options, but it's not working so far.
Suggestions greatly appreciated.
26 Replies 26
Dave Jochum
I have experienced BACKGROUND FILLS that won't layer properly--that is, it will not recede when I change the DISPLAY ORDER for an overlapping element a la BRING TO FRONT. Don't mean to confuse the issue here, but just saying there may be more than one bug associated with BACKGROUND FILLS. Sorry I can't help.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.6.1•AC 29 Silicon (latest build)
One thing worth mentioning, It does not show in the layout book. Which is good, but why, why, why!!!
Jeff wrote:
Strange you know....it's only when I set the background fill color to white that the fill shows grey, and yet when I select any other color (brown,black,red,etc) it is shown correctly.
It makes no logical sense whatsoever, this is why I suspect it is a bug.
Jeff
If your window background color is white, that sounds to me like the never-enough-celebrated 'Automatic Pen Color Visibility Adjustment for Model Views' setting hidden in Work Environment, User Preference Schemes, More Options. That should be unchecked.
Briliant Ignacio!
That was it. What a strange little obscure option.
Thanks you so much.
Jeff
Thomas Holm
It's no so strange. It's the only way you'll ever see a white fill on a white window background, and be able to distinguish between a white and an empty fill. It doesn't print and doesn't get in the way. I prefer to have it on!
Of course this is only a problem for those who still use a white background! Everybody knows that beige is the way to go!
Dwight
With sepia line work and Leonardo font.
Dwight Atkinson
