Chris Pooley
Floor Plan Cut Plane Settings
Hi all,
I am having troubles working out what I am doing wrong with my settings?
In the attached images, the wall is sitting at just over 600mm from its associated FFL, so I thought if I set the cut plane at 800mm I would see it cut through? The walls next to it are sitting on the FFL and are 1100mm tall.
Thank you,
ArchiCAD 19 to 27
Windows 11
1 Solution
mthd
Hi @Chris Pooley, have a look and see what your story settings show for your floor to ceiling heights first. Maybe that might give us an indication of what might be causing the problems for you ?
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
Go to post
4 Replies 4
mthd
Hi @Chris Pooley,
So, as I understand the floorplan attached is the ceiling level, right?
Ok if the parapet wall's home story is ceiling level one with a bottom offset 600,
try to set the wall's floor plan display to symbolic cut or if you like to keep it projected you should set the floor plan cut plane as attached SC below.
AC 29 INT 4006/WIN 11
Chris Pooley
Thank you for that, it was that I had the floor to ceiling height set to 300mm, as there is no floor above it.
Thanks again.
ArchiCAD 19 to 27
Windows 11
mthd
No worries, I am glad that you figured it out from the story settings. You never really know exactly why things don’t display correctly, a bit of hit and miss sometimes. All good to go now.
