Lasha97
Garage Door
This is how Garage Door appears on the Elevation Drawing
this is how Garage Door appears on the Layout
What to do?
Setup info provided by author
1 Reply 1
If I had to guess, I would say you did not use a view from the view map to place on your layout.
If you did, then check the settings to see what Model View Option combination it is using - I think you will find it is using one that has 3D door level of detail set to simple.
