Get 2d drawing (worksheet) from 3d view
Hello Everyone,
this is probably a very basic question...
I want to stand in 3d view and capture the view (or parts of it) as a 2d line drawing to place on a worksheet... I know how to do it from plan and elevations. There I just mark the objects I want as lines and ctrl+c and then ctrl + v on the worksheet, WORKS PERFECT! How do I do this from a 3d view?
Thank you in advance..
4 REPLIES 4
David Maudlin
Brainmaniac:
You can create a 3D Document by right-clicking in the 3D Window and selecting New 3D Document from 3D..., or use the flat Marquee to Copy and Paste from the 3D Window. The 1st creates a live connection to the model, the other just 2D elements.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you David! I followed your instructions and voilá: I Have an avatar!
About my issue though. Thank you for your input. When I do the copy and paste that you proposed I just get and image (!) insrted.. no actuall lines ? What am I doing wrong?
Ok so we figured it out here! In my 3d window settings I had the openGL instead of Vectorial engine. Once that was changed it worked. THank you for your help anyway.
David Maudlin
Brainmaniac:
Glad you worked it out, thanks for posting back and adding the signature.
