gdford
Graphic Overrides - cleanup
I am trying to figure out how to clean up unused graphic overrides and graphic override rules.
I see that I can run a report in the Drawing Manager that will list all of the drawings on layouts and the graphic overrides attached to those drawings.... So that is a start for the Basic overrides.
How might i go about to purge unused graphic override rules?
I am not finding any flags that tell me if a rule is in use or not?
Does anyone have thoughts on this?
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
12 Replies 12
Lingwisyer
Guru
Exporting used GOs, deleting all GOs then reimporting them sounds like a good idea to test.
mgg
We can’t reach the BIMdots website. Is this an issue with our network, or is anyone else having the same problem?
AC 26-29 GER
Windows 11 // i7-10700 CPU @ 2.90GHz // NVIDIA GeForce RTX 3070
The link Botonis gave works for me.
