Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Graphic Scale for ArchiCAD Layout
How can I add a graphic scale to a layout page?
2 REPLIES 2
runxel
Hero
There is an object in the library, should be called something like "Scale [version number]".
EDIT:
I kipped there. Of course I mean't to write don't place it on the layout. It needs to be placed in the view to maintain right size.
David luckily catched this. šŸ˜‰ thanks!
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
David Maudlin
emartinez:
The Graphic Scale_NCS 21 needs to be placed in a View (plan, section, etc.) to display correctly in a Layout. The Drawing Titles "NCS Drawing Title 21" and "NCS Drawing Title 2 21" have an option to add a graphic scale to the Drawing Title which will show correctly on the Layout.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
