Graphic override for zone schedule
Achille Pavlidis
Is there a way to have a graphic override that marks with red pen the zones in a schedule that are new according to their renovation status?
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
5 REPLIES 5
Erwin Edel
The only way I can think of making this work is by having a schedule for existing and a schedule for new and just adjusting the pens for each. I don't think you can use GO for overriding text in a schedule.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
I have just experimented in version 21 so not sure if there is anything different in 24.
It seems you can't change the zone foreground colour because they don't have a standard pen colour.
You can change the background colour if you override with a 0% (background) fill and set the background pen to be overridden.
There may be a default zone transparent rule for this, I used that and changed the background pen colour.
It is possible to change the colour of the text but in a rather round about way.
There is no criteria for the zone text, but if you set criterial for all 2D elements and then exclude all of the 2D elements, you seem to be left with just the zone text.
Achille Pavlidis
Thanks for the replies.
What I'm looking for, is what Erwin said, i.e. a text pen override in a schedule that lists both new and existing zones, where the new zones are marked with a different color
It seems it is not possible to have this in a single schedule
Sorry I missed the schedule part for some reason.
No you can't use GO in a schedule to change the colour of some of the text fields.
You can list the renovation status of a zone in the schedule and you can group by that reno status if you want.
Yes, I think the situation here is that you can actually apply a Graphic Override to a Schedule, but I think it will override only the cells that have graphical information in them, like a "2D Symbol" or a 3D Front View", and so on. Graphic Overrides do not have an effect on other schedule cells. At least this is the result I got when I just tried.
