Grid Line display order in 3D Document
Dave Brach
I have created a top view 3d document for use as a Roof Plan.  But I am unable to get the Grid Lines to show on top of the drawing.  I have to turn off the mesh to see them or select them, and even then I cannot "bring to front" in the display order.
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
Hi @Dave Brach,
You can see your grid above the mesh if you elevate the grid level to the top surface of the mesh from this dialogue via (to project zero).
AC 28 INT 3110/WIN 11
Hi @Dave Brach,
Mahmoud, thank you, that works!  Of course now I am seeing why it would be nice to be able to adjust the linetype;  also, the Grid numbers/letters are casting shadows
AC26 MBP OS Ventura
Thanks Dave, you're welcome.
