2025-07-06
		05:56 PM
		2025-07-06
		10:02 PM
Hi I'm having a problem with one fill type when plotting - the lines thickness get much larger when plotting vs. when viewing before plot. See attached view before and after. Is there some type of setting I am missing? Thanks
2025-07-06 07:56 PM
Maybe these are 2 different views, cause it for sure looks you have 2 different pen sets.
2025-07-06 10:05 PM
You could also try to Plot with the "Hairline" option enabled and see if that achieves the desired result.
2025-07-06 10:37 PM
The first view is from the view map and second is plotted and I just took a screenshot of the pdf.
2025-07-06 10:49 PM
Where is the hairline option for plotting? I think it is hairline by default for on screen view options
2025-07-06 11:27 PM
Also forgot to mention these are zones that are using a cover fill
2025-07-07 09:35 PM
If you use the File > Plot Dialog, you will find a "Hairline" checkbox there.
If you Publish to PDF, in the "Document Options" Dialog of Publisher Sets, there is also a "Hairline" checkbox.
2025-07-08 02:44 AM
The white pen for the grid lines in the fill is probably a very thick white pen.
You could change it to a thinner pen or edit that pen in the pen set to be thinner (that will affect everything that uses that pen).
