2014-09-25
12:14 AM
2023-05-26
12:05 AM
Gordana Radonic
2014-09-25 12:55 AM
2014-09-25 01:09 AM
2014-09-25 01:27 AM
NCornia wrote:
Rob,
•Layouts do not have the same function as a saved View.
•So you need to set the zoom after opening the layout.
•However, the zoom factor will remain constant for all layouts until you zoom in or out to a different zoom factor.
•You can use theFit in Windowcommand have the layout quickly fill the space.
Default keyboard shortcuts forFit in Window:
Mac: COMMAND + '
Windows: CTRL + '
I was discussing a wish tangential to yours with a colleague just recently. I'll add your topic as part of the discussion for a future improvement.
Best regards,
2014-09-25 01:32 AM
2014-09-25 01:59 AM
s2art wrote:
I often have layouts with extra views outside the printed area, so would not want these to Fit to Window automatically.
2014-09-25 02:42 AM
rob2218 wrote:Clarification: The zoom factor is the same for all layouts in terms of percentage. If you have all 24x 36 sheets and you have zoomed to a percentage that fits the entire layout in the window then all 24" x 36" sheets will be framed the same. If you have a mix of layout sizes though then the 8.5" x 11" sheets will fill less of the window and if you have a 42" x "36" sheet then it will show as cropped.
Now..do ALL layouts react to the same zoom extents or is it a 'per layout' condition as to how it will look from layout to layout?NCornia wrote:
2014-09-25 05:03 AM
2014-09-26 07:22 AM
NCornia wrote:Shorter Shortcut:
Mac: COMMAND + '
Windows: CTRL + '
2014-09-26 03:58 PM
GraemeB wrote:If I have a layout book with hundreds of layouts I'd rather zoom a couple of times when switching sheet sizes rather than set hundreds of saved views. And what happens if you change the master to a set of drawings?
It would be a really useful enhancement for each layout view to be "saveable" or remembered. It is annoying for me when switching from an A3 size layout to an A1 size, and having to zoom out, then reverse the process if I switch back to a smaller (A3) size layout.
