rob2218
Hatch patterns for "earth" and 'story setting displays'??
In Autocad, (sorry to keep referring to it but..) there was a hatch pattern that was called 'weave' or 'herringbone' or something like that which architects used as an "earth" pattern in section.
Archicad's "earth" hatch pattern is a bit lacking and I'm being given hell for it at the office where I'm consulting for.
Anyway I can either A) import any autocad hatch patterns into archicad or
B) perhaps how do i edit/modify the "earth" hatch pattern to make it look like the example (see red lines).
Also, the story settings.....how do I get them to read as "42'-0" not just +42' (only showing the "feets" and no inches"??? please advise.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
10 Replies 10
Eduardo Rolon
You can create the fill easily in AC.
Page 1015 of "AC 13 Reference Guide" under help.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
rob2218
A friend suggested I use the "merge drawing" technique?
is this not the way to do it?
to create an autocad drawing, put the hatch patterns which I want, then use the "merge DWG" into the Archicad file???
is this not correct??
i>u
Edgewater, FL!
SOFTWARE VERSION:
Eduardo Rolon
AFAIK that works also, though I prefer to use/create my own instead of using Autocad's.
If you read the manual you will see that it is really very simple to do.
It might be easier to create it than to import it and you will learn a new procedure.
AC29 US/INT -> AC08
rob2218
ok....will try to "create my own" hatch patterns.
At least I'll learn something new eh.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erika Epstein
rob2218 wrote:
hatch
That is soo autocad.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Even Archicad uses hatching, Erika...
Erika Epstein
one of the 'lets appeal to autocad' inclusions
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
rob2218
What about the second part of the question?
How to get the story settings to read as "FEET AND INCHES" rather than just the FEET ???
i>u
Edgewater, FL!
SOFTWARE VERSION:
Srinivas
You can chage the story level dimension settings under Options > Project Preferences > Dimensions > Level Dimensions > Display of Zero Feet & Inches:
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
