ananas
Heavy PDFs with Archicad hatches
Hi!
I am struggling with PDFs exported from Archicad including hatches. They get super heavy and I don´t understand why because if I use the same hatches in software as Adobe Photoshop or Illustrator I am able to compress the PDFs well by export.
Should I set PDF export files differently or does anyone know how to deal with these heavy PDFs from Archicad?
Thank you!
6 Replies 6
Patrick M
this has been an issue for quite a while. I have just eliminated any overly complex fills from my templates to avoid bloated PDF's. And watch out for any team members creating custom fills with too many arcs/lines. Other than that, you can flatten or compress a pdf after publishing, but that can also create issues, depending on what it is being used for.
runxel
Sounds like you're using the vectorial fills.
Vectorial fills will stay as a fill in a DWG, but will be single lines and arcs in a PDF.
For symbol fills it is the opposite. They will be exploded into lines in a DWG, but stay as a fill in a PDF.
ananas
Hi!
Thank you for answering! I actually use low quality seamless jpg textures. I´ve actually always been struggling with PDFs including hatches from Archicad and I don´t understand why. A workaround I use is that I use the same hatches in photoshop and then combine PDF lines from Archicad with JPG textures from photoshop. As long as we don´t use any hatches from Archicad, there are no issues.
It would be great though if we could export everything directly from Archicad though, to avoid double work.
runxel
Image fills are notoriously bad with Archicad, sadly.
There is no silver bullet for you. We can only hope GS will improve its PDF export by a ton in the near future.
(One would have guessed so with the advent of the possibility of image fills in sections, but alas)
ananas
Understood, thank you for answering!
ananas
Hi! I am wondering if this texture hatch improves in newer versions of Archicad in 25 for example?
I would now export the textures as jpg and the lines as PDF and join them in InDesign later, but somehow exporting jpg from Archicad ends up in very low quality. Do you maybe know why and how to improve jpg export quality?
