How can I stop the glass to project further?
So I got a curtain wall, slim frame and big glass panels, the problem is that if the glass projects further as u can see on the picture the section becomes really really messy, im sure its a dumb thing to fix but cant figure out how to solve it.
Thank u so much.
runxel
Hero
I guess he wants the glass to be opaque.
Just disable the transparency in the section.
(Or make a special glass with a transmittance lower than 50 and assign it to the glasses you want to have opaque – they won't show the things behind even with transparency enabled.)
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
Guru
What do you mean "glass projects further" and can you supply and image of the section in question?
There's so much going on in that section that you've provided that it's hard to see what's going on... A triple and double sash window with divided transoms that act as a wall between a living room and a kitchen?
Ling.
runxel
Hero
Yes, thats it, i want it opaque, sry I explained myself so bad.
Thank u so much
