How did I make the level markers disappear from only one section?
Gisele
1) I hid the level markers on one of the elevations by mistake; but I am NOT sure how?
2) Is there a way to extend the level markers lines? (See attached screenshot for the red hidden line that I added manually).
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
2 ACCEPTED SOLUTIONS
Gisele:
Your "section Settings.jpg" says "Default" in the upper right corner. Do you have the section selected that you want to modify?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I was able to modify the story levels settings, but the changes do not reflect on the sections! (See attached screenshots).
Gisele:
