How do I do a wipeout under the window when exporting?
LeeJaeYoung
What should I do with the bottom of the window?
From my point of view, it only believes in the function called WIPEOUT and does not calculate the relationship with the wall at all.
I think you should consider the FILL area with the wall once.
in archicad
in AutoCAD
AC27 on window 11
Aaron Bourgoin
Wipeouts are created when the background fill pen is set to "screen" colour. I discovered this by accident when trying to eliminate them, but it might be helpful in your case.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
When exporting to AutoCAD, wipeout does not occur in the wallhole2 part.
I'd like to know what you mean by how to solve this.
AC27 on window 11
