LeeJaeYoung
How do I make the outline of a wall invisible?
These are beam walls located at GL -1200.
1. What method should I use to make the lower wall invisible?
a. Home only
b. Display order down
c.
d. ????
2. But if I use c, I would like to know how to make it appear on the screen again.
3, I divided the lower floor wall into two parts, one of which was covered by a slab and expressed as a hidden line, and the other was the same wall, but I wanted it to be shown as an elevation line, so I divided the wall into two parts and handled it like this. Is there another way?
AC27 on window 11
0 Replies 0
