LeeJaeYoung
How to override door or window fill?
Solved: How to override door or window fill? - Graphisoft Community
I want to change the fill for window wallhole2 in GOC.
No matter how much I do, there is no change in Fill.
AC27 on window 11
1 Solution
Glori_aaa
Not sure if I understood correctly but it seems like you want to override the portion of the wall that is uncut, and showing whenever you have a window or door placed.
You can override it in this way:
Go to post
2 Replies 2
Glori_aaa
LeeJaeYoung
Draft Fill
Cover Fill
Cut Fill
I still don't know how to use draft fill.
And I did this far yesterday.
So I thought no. ^^
Because I only use it with everything turned on lol
I appreciate your interest. ^^
I wish you a happy day.
AC27 on window 11
