‎2024-08-14 07:21 PM - last edited on ‎2024-08-15 12:06 AM by Karl Ottenstein
trying to figure out how to make the master project border stream-line with project changes. any suggestions on work flows or links to them concerning project revisions, approval etc., not sure how change manager works with the text ID elements that i have placed in our project master border. TBH not sure what questions i need to ask for help?
Operating system used: Mac Intel-based Sonoma 14.5
Solved! Go to Solution.
‎2024-08-14 11:28 PM
At first glance:
For the vertical ones you will use the "Revision History Detailed 27" object placed on a Master Layout.
For the horizontal ones you will use autotexts.
Recommend to read up the help file
For the attached image:
Index Settings are:
another Moderator
At first glance:
Index Settings are:
another Moderator
‎2024-08-15 04:28 PM
thank you @Eduardo Rolon! appreciate the short tutorial 😀 i did attempt to read the help but as usual time is always short. regardless thanks and will do a better job of explaining myself next time.
