LeeJaeYoung
I want the dimension to be at 1500mm. But what should I do?
AC27 on window 11
2 Solutions
Double click to get the hammer.
Move the cursor to the point you want to measure the 1500 from.
Type X or Y (for horizontal/vertical - X for your image above) and then 1500 +/- (depending on the direction you want to go and then ENTER.
Go to post
Yes, double click to bring up the hammer icon.
Hover the mouse over the point (line) where you want to measure from.
Type X1500+
ENTER.
See attached video.
Go to post
8 Replies 8
LeeJaeYoung
You said “Your explanation is to point the mouse at the reference point, specify the direction of the X and Y axes with the key, and specify the relative distance as 1500+.” Is that correct?
You're saying to use the "+" you pointed out. ^^
Today too I wish you a happy week start. ^^
AC27 on window 11
Type X1500+
ENTER.
See attached video.
LeeJaeYoung
thank you
It's sad that I can only tell you this.
If it were Korea, I would have eaten soju and sashimi by the seaside with you. Or, live octopus, which foreigners fear, is also possible. ^^
AC27 on window 11
LeeJaeYoung
Is there a way to make the text appear like this?
I don't have these borders.
AC27 on window 11
It is an On-screen View Option.
Your menus may be a bit different to my customised ones.
Yeah, I'm not sure about the live octopus!
LeeJaeYoung
Thank you for always.
There are many delicious things in Korea, but there are many things that are not well known in the video. Only beach people like me ate....
It came up a lot in the video.
처음 산낙지를 먹어본 외국인 반응 Feat. 덴마크 여자 3인방 [도시락 | 코리안브로스] - YouTube
AC27 on window 11
Eduardo Rolon
FYI, for "Feet and Inches" you need to remember to type "- -" (2 dashes) to go in the negative direction.
Typing " - +"  (dash, plus sign) also works.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
