2023-05-15
		02:58 AM
		2023-05-30
		09:52 AM
			Rubia Torres
2023-05-15 03:11 AM
Remember that Graphic Overrides affect the entire element.
So even though you are filtering for walls with a blue uncut line, that will just find all walls that happen to have a blue uncut line.
Any walls that it finds will be completely changed by the overrides you set.
The actual overrides do not differentiate between cut or uncut lines.
2023-05-15 03:11 AM
2023-05-15 03:21 AM
Yes, your answer makes me give up.
thank you
I'd rather apply it instead of HIde.
2023-05-15 03:35 AM
Sorry, clarification.
You can 'hide' the uncut and/or cut lines of the element but you can not override the pen colour for uncut/cut lines.
I tend to work in version 22 that doesn't have that option to hide them.
2023-05-15 04:16 AM
I guess the translation is not good.
I want to thank you for solving my problems
Instead of the option to hide it, I said that I would like to have an option to apply only the elevation line I wanted.
thank you ^^
I had a lot of questions while studying over the weekend....
I beg you well.
2023-05-15 04:27 AM
thank you ^^
Yes, I understood that.
I didn't even realise there was an option to hide the lines until you mentioned it, so I just wanted to clarify for others reading this that you could hide the cut/uncut lines (as you discovered) but not change their colour.
Because in my first post I said "The actual overrides do not differentiate between cut or uncut lines".
But they do if you want to hide them.
