‎2004-08-23
10:28 PM
‎2023-05-19
04:07 PM
Gordana Radonic
‎2004-08-24 04:01 AM
‎2004-08-24 02:00 PM
‎2004-08-24 03:57 PM
‎2004-08-24 07:51 PM
‎2004-08-24 11:15 PM
‎2004-08-25 12:08 AM
Michael wrote:I have not seen this problem myself so I don't know what could be causing it. Views in the solo project should automatically be shared when creating the teamwork files.
1) The first problem I have is that when views are defined in a solo project file and then the project is shared, the views are not accessible to the team members. This is a problem because many of our files begin as a solo file and aren't shared until well into the project.
2) The problem described above. When changes are made to layer combinations, the information does not seem to seamlessly update in Plotmaker.Make sure the layer combination is properly specified in the view and the layer settings are not being overridden in PM. If these are set correctly and you still have problems we are back to your glitch.
3) This is not an AC problem but I could use some feedback: Several of the computers in our office are Mac G4 400MHz w/768 MB RAM. Are these computers enough to efficiently run AC 8.1 (not including high-resolution 3D work)?We have a couple of G4 Cubes at 400 MHz which we have used to run ArchiCAD 8.1 acceptably. They were truly painful to use for 8.0 but the performance is much better under 8.1. You are right not to expect great 3D perfomance, but it might not be too bad if you have good video cards and can use OpenGL.
As far as problem number 1 & 2 above, I know there are work arounds to solve these but in our office getting everyone to understand these work arounds is not a realistic solution and I don't have the time to do it for them. My primary concern is that AC 8.1 has been around for a while now and things still do not seem to be working as they should with the program.These are not normal problems in my experience. Perhaps your dealer or Graphisoft can help you with some troubleshooting.
I think there are some great features in AC 8.1 which could improve our efficiency, but some of what I consider to be key problems are cancelling out the perceived improvements. Should we bother to upgrade or wait for AC 9 to see if these glitches are solved and the program works the way it is intended too?A year ago I would definitely have recommended the upgrade to 8.1. With version 9 on the way it probably makes more sense to wait. You may want to revise some of your standards once you see the new features and it makes more sense to just go through the process once rather than twice in close succession.
‎2004-08-25 01:17 AM
