2015-10-07
11:14 PM
2023-05-17
09:19 AM
Gordana Radonic
2015-10-07 11:41 PM
2015-10-07 11:50 PM
2015-10-08 02:59 AM
Steve wrote:This can be done but depends on how you select the marker and the points you stretch,
I am not able to adjust Individual Interior Elevation Markers making them wider or narrower than they have been initially made.
2015-10-08 06:55 AM
2015-10-09 01:55 AM
2015-10-09 09:06 AM
Erich wrote:Yes the marker range helps to show this line but for me it is a fairly widely spaced dotted line and still very hard to see.
Steve, the "Marker Range" command will toggle the visibility of those lines on and off. I keep that one in my customized tool bars at all times.
2015-10-09 06:33 PM
Barry wrote:I believe it is using Line Type Attribute #4. This is Dashed in the standard setup. If you go to Attribute Manager, delete all the Line Types except 1 to 3, then import another Line Type that will become #4, it will be the limit line type.
But does anyone know if you can change the line type used?
I don't see a setting anywhere.
2015-10-09 09:06 PM
Erich wrote:Thanks Erich, I always have that on a tool bar too. I think this is the first time I have ever clicked that button.
2015-10-09 09:11 PM
David wrote:or you can make some changes hereBarry wrote:I believe it is using Line Type Attribute #4. This is Dashed in the standard setup. If you go to Attribute Manager, delete all the Line Types except 1 to 3, then import another Line Type that will become #4, it will be the limit line type.
