Interior elevations problem
Arcadia
I have just opened an old V13 project in V14 and found that interior elevations I had that had a vertical limit set with the bottom level above the project zero (ie a bathroom on a higher split level that does not have its own story level) have diseappeared and only the 2d text and dimensions appear in the view. I found that I could put new interior elevation markers in and the 3D stuff appeared okay but as soon as I then entered a higher bottom vertical limit the 3d stuff diseappeared. Is this a bug in v14 or am I just missing some new function or option or something?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
This Thread might be useful, has cross references and site urls.
Snap
Arcadia
All very interesting thanks but no help with my issue. Hopefully it is a one off and doesn't occur again as I can see no reason for it and it has worked fine in the past. I got around it by just placing new IE's with the vertical limit at zero then masking off the bottom in the view.
You will probably find just a standard section or elevation will work properly.
Interior elevation always seem a little buggy to me so i never use them.
