Arcadia
Interior elevations problem
I have just opened an old V13 project in V14 and found that interior elevations I had that had a vertical limit set with the bottom level above the project zero (ie a bathroom on a higher split level that does not have its own story level) have diseappeared and only the 2d text and dimensions appear in the view. I found that I could put new interior elevation markers in and the 3D stuff appeared okay but as soon as I then entered a higher bottom vertical limit the 3d stuff diseappeared. Is this a bug in v14 or am I just missing some new function or option or something?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
3 Replies 3
This Thread might be useful, has cross references and site urls.
Snap
Arcadia
All very interesting thanks but no help with my issue. Hopefully it is a one off and doesn't occur again as I can see no reason for it and it has worked fine in the past. I got around it by just placing new IE's with the vertical limit at zero then masking off the bottom in the view.
You will probably find just a standard section or elevation will work properly.
Interior elevation always seem a little buggy to me so i never use them.
