alessiofazzi
Is it possible to automatically create a bold contour line in elevation view?
I would like to have a bold line that contour the main subject of an elevation, like in this sketch?
1 Solution
Eduardo Rolon
There is no automatic way to do this.
The workaround is to draw a rectangle around the elevation and then magic wand a polyline in the space.
    1. Use scissors to remove extra line elements
  4.
  6. If project changes then redo.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
2 Replies 2
Erwin Edel
You could setup a view with layer combinations, model view options and graphic overrides to get close, but I think you will still see an outline for doors and windows as well. You could stack this view on top of your normal view on the layout.
We use a similar approach to show basement level contours as dashed lines for our elevations. But basements generally don't have doors and windows on the outside.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Eduardo Rolon
  4.
AC29 US/INT -> AC08
