LeeJaeYoung
Is this section marker possible?
AC27 on window 11
4 Replies 4
Eduardo Rolon
Yes
Depends on your Library. In the US version it is called "Section Part Marker NCS"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Patrick M
you can use 'custom text' for any section/elevation marker I have ever used
LeeJaeYoung
Thank you
How can I get it?
AC27 on window 11
Eduardo Rolon
Check the options in your current library to see if there is one. If not you can download  and install the US version and extract from the library.
https://graphisoft.com/downloads/archicad/install/AC25/USA
AC29 US/INT -> AC08
