Jogging A Section Cut
I was hoping one of you might know how to jog a section cut. I know that I can jog a section cut @ a 90 degree angle, but I cannot find out how to change that angle. Basically I want jog the section along the dashed blue line on the attached PDF, is this possible, or should I just give up now?
3 Replies 3
You can only look at a section in one direction. You can have a breaked section.
But maybe it is a work around to create 2 sections and place them adjacent on a layout?
I had the same task.
My way was create two section on the same ID later will joint it in layout.
or you can use the Interior Elevation tool
gpowless
Why not do a 3d cut and turn the viewpoint on to a side view?
Intel [email protected] 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
