JelenaKujundzic
Layout and model colors not the same?!!
I have a problem with colors in ARCHICAD 21:
-when I am drawing in project map, everything is fine, it is all drawn in shades and colors that I want, and then when I drag my drawing (Elevation) from model map to Layout book the colors change into one shade (everything is green )
I have tried switching the pens&colors to the same pen set but nothing happens... Does anyone know what I am doing wrong here?
Thank you
3 Replies 3
Guru
Checked the colour settings in the layout?
Drawing Settings -> Colours
Ling.
James B
The Layout is using a different Pen Set - check the Quick Options Bar at the bottom.
James Badcock
JelenaKujundzic
Hi, thank you for your quick reply.
I found the solution- in layout book - i right clicked on the dragged drawing - and then selected "Modify source View Settings" -> and then in General section -> Renovation Filter: I changed from Missing to 00SHOW ALL - and then the fills and colors changed to the same ones as the model.
Thanks again
Cheers
