Layout naming not behaving.....again in AC20?
rob2218
so, seems I run into this everytime I setup a new project.
Not sure which toggle, radio button, check box, blip, jip, nip...I should be toggling on or off.
Seems the sheets (Layouts) naming and number don't want to follow the subset rule.
What did I do wrong? where do I fix it?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
sinceV6
Hi.
Screenshot is kinda small, but I can barely see that the layout settings screenshot is using "Custom ID" instead of "Automatic ID", thus not following the subset rules.
Best regards.
rob2218
thank you.
i>u
Edgewater, FL!
SOFTWARE VERSION:
