‎2015-10-15
08:08 PM
‎2023-05-22
11:56 PM
Gordana Radonic
‎2015-10-16 11:00 AM
‎2015-10-16 03:18 PM
Tincan561 wrote:After placing the Level Dimension, select the text of the dimension(s) (multiple texts can be selected at once), and change the text value from Measured Value to Custom Text, then select the to Sea Level option.
I would like to set the origin of a Level Dimension in a floor plan to Sea Level instead of Project Zero.
How do I set the origin of a Level Dimension in a floor plan with v.19?
‎2015-10-16 03:27 PM
‎2015-10-16 04:52 PM
‎2015-10-18 07:14 PM
laszlonagy wrote:As the sales pitch once said: with ArchiCAD, there's almost always one way:
Currently you have to select all Dimension Texts one by one. This wish would greatly speed up their selection.
‎2015-10-18 07:27 PM
‎2015-10-19 03:13 PM
sinceV6 wrote:Maybe I'm missing a step, but this does not work for me. The Info Box remains showing the parameters for the Level Dimension Tool, not the Dimension Text Tool.laszlonagy wrote:As the sales pitch once said: with ArchiCAD, there's almost always one way:
1. Activate the level dimension tool.
2a. Hit CTRL-A to select all level dimensions, then shift click one of the text boxes to select it.
2b. OR do it backwards: shift click one of the text boxes then hit CTRL-A to select all level dimensions.
3. Change the custom text to your liking.- sea level in this case.
You just have to make sure that after selecting all elements, the last selection is still the level dimension text box, so that the info box shows the text box parameters, not the level dimension parameters, and you can change everything in one go.
‎2015-10-19 03:42 PM
‎2015-10-20 03:06 PM
