JCCARLOS91
Level dimension direciton
Is there a way to maintain the direction of a level dimension? We want the head of the dimension to always be on the left and the text on the right above the extension line.
We have a project where we have 4 villa types hot linked into a masterplan file. Each of those villas types are copied and mirrored in different plots. Because of these, the level dimensions are flipped and then clashes with dimensions and other texts.
What is the best approach for this? Thank you.
John Carlos
AC25 | iMac 2019
1 Reply 1
Lingwisyer
Guru
Can you share an image of the issue?
