2005-04-14
05:06 PM
2023-05-30
03:27 PM
Rubia Torres
2005-04-15 09:15 AM
2005-04-15 09:41 AM
Ronald wrote:A Label that reads the height would be OK.
My project requires that I note the height of each wall on the plan. I thought the level dimension marker would do this easily but it appears not to work with walls . . . what's up with that! Any solutions?
2005-04-18 06:28 PM
Ronald wrote:If it has not been posted as a wish it should be. I know I have been forced to model foundations with slabs instead of wall in areas with complex stepped foundation if I want to use the level dimension abilities in plan view.
Ron
2008-11-09 12:16 AM
2008-11-11 05:19 PM
Karl wrote:Can you please post it in the Depository as Geoff is not around at the moment?
In case someone stumbles across this old thread doing a search... Geoff posted a label for wall heights here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=38432#38432
2008-11-11 07:28 PM
Djordje wrote:Done. It is now in 01 General > Custom Labels
