Level dimension marker on walls
My project requires that I note the height of each wall on the plan. I thought the level dimension marker would do this easily but it appears not to work with walls . . . what's up with that! Any solutions?
Surely some bright person out there has run across this problem and found a solution.
Ron
6 Replies 6
Petros Ioannou
hi Ron,
there is a "locator" object from Archiradar at
http://www.archiradar.com/eng/objects/portaoggetti.htm
Check "graphic operators"
You can adjust it's position in the 3d window and see the values on plan.
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Djordje
A Label that reads the height would be OK.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Ron
If it has not been posted as a wish it should be. I know I have been forced to model foundations with slabs instead of wall in areas with complex stepped foundation if I want to use the level dimension abilities in plan view.
In case someone stumbles across this old thread doing a search... Geoff posted a label for wall heights here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=38432#38432
Karl
Djordje
Karl
Can you please post it in the Depository as Geoff is not around at the moment?
Djordje
HP Omen
Done. It is now in 01 General > Custom Labels
http://archicad-talk.graphisoft.com/object_depository.php?
Karl
