2006-11-21
		09:19 PM
		2023-05-23
		12:02 AM
			Gordana Radonic
2006-11-21 11:53 PM
2006-11-22 01:13 AM
andyro wrote:
http://www.archicad.ca/?p=13
Does that help? Use gravity on (for mesh or for slabs, you have to tell it which), and switch the little toggle to your defined reference level before dropping your markers. They are associative to slabs, but not to meshes if warped, only if elevated (I think). We use ref levels to get elevation/section level markers to read correctly as well as on plans.
2006-11-22 01:38 AM
Link wrote:doens't work for me either. the level dimension tool has no offset/dimension origin the section
Andy, are you saying that by changing the Z Value in the Coordinate box first, the gravitated level dimension will refer to the reference levels as you place it in plan?
Now, go to a section window, select the level dimension tool, and make sure instead of project zero, your dimensions are set to be relative to ’sea-level’ or whatever you called your reference level (in this case it is called ‘average grade’), and throw a dimension or two on your structure. NOTE: ’sea-level’ will show up on every marker. If you don’t want this, start your string, and ctrl-click the rest of the markers along the string - these will arrive without the name, just the value.i often never want that bloody suffix text, so this tip is going to be a real help! thanks!
2006-11-22 05:11 AM
2006-11-22 05:20 AM
2006-11-22 05:33 AM
2006-11-22 05:35 AM
2006-11-22 05:39 AM
2006-11-22 05:57 AM
~/archiben wrote:I wasn't going to say it!!
are you sure your project zero isn't at the 'correct' height relative to sea level to begin with, andy?!![]()
ben
