‎2023-01-31 09:53 PM
And if it is my high res screens let me know.
I am having a hard time with the line weights you cannot see. I come from another platform that is wysiwyg.
Not a great program but that helped with detailing
I feel like I am guessing because I really don’t see a good interpretation on what I am getting until I go to PDF.
Are there any thoughts from others As UI largely just want black lines with thickness. For me colors would typically guidelines so that they dont stand out against the drawing.
‎2023-02-01 12:23 AM
Have you tried turning on True Line Weight in display options?
‎2023-02-01 04:34 AM
Does to work very well - I king of end up with thin line and very thick line. and as you scale it does not do the same.
‎2023-02-01 01:43 PM
Colours for lineweight is a matter of pen sets.
You can assign a different pen set to your placed drawings on layouts (for black lines) and use one with colour coding for your saved views.
I worked like this for many years. Red = 0.18, black = 0.25, green = 0.35 etc etc
So if your template only has a black pens pen set, you can duplicate this and modify the pens to have colours you are used to from your other software.
‎2023-02-01 08:40 PM
But that is still guessing. It is not WYSIWYG.
This is even bigger with a higher resolution screen
I tried a lower res screen that is collecting dust and the ability to see thickness is a little better but on Hi res harder.
It will take some time to get intuitive enough for the best drawings. They need to equal what I do by hand. Started that way.
‎2023-02-14 06:31 PM
I only need black with a few colors - that is all fine
The problem is that when I set up 10 black pens with 10 different line weights - the pens just don't show a gradual change from one to another.
‎2023-02-15 03:09 AM
I don't understand what you mean.
The pen thicknesses are exactly as you set them.
So they can be what ever you want.
‎2023-06-13 10:23 PM - last edited on ‎2023-06-14 03:49 AM by Barry Kelly
When I open up on. My high resolution screen my lines look all very thin. I dont see this clean variation anywhere
Doing this for 40+ years and I probably have 10 weights that I am used to seeing all black as I want it to look like the plot. And then a few colors for special things
Wt is what matters as B&W is what you see in the field and on a plot
‎2023-06-14 03:59 AM
Personally I can't stand working on screen with true line weight turned on.
I work in hairline with coloured pens.
I know each colour represents a particular line thickness - a bit like the colours of the old Rotring ink pens.
Then when I place the drawings on a layout, I set them to use a black & white pen set (it does have a few coloured pens as well).
Each coloured pen I used on screen is the same pen thickness, but now black instead of colour.
So I have the best of both worlds.
I can easily model in plan in hairline, but print in black & white with true line weight.
I would like to see a screen shot of some sample lines that you see on screen with true line weight on, and what the weight (thickness) of each of those lines is.
‎2023-06-23 04:19 AM
And I don't like it when the screen does not look like the drawings.
Just need a representation and not a guess
