List of Zones with Hotlink file as field
Achille Pavlidis
I have a project with many Hotlinked files, with zones that have the same name across different files. I want to have a list of zones with the hotlinked file that each zone is associated with. Is it possible?
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
Select the hotlink (make sure grouping is not suspended) and then right mouse click.
Choose 'Hotlink Selection Settings'.
What about creating a schedule that list the zone names as well as the 'Hotlink Master ID'.
If you have given each hotlink a 'Master ID', that should work.
Hmmm, now that I haven't, I cant set afterwards?
