SamBruchez
Louvre windows not openable in 3D document
Hi everyone.
I have been unable to figure this one out on my own. I am using Archiad 25 and the object in question is Cadimage Windows. The windows that are modeled with louvre blades, are openable in the 3D view. However, when I save as a 3D Document, they are closed. I cannot find anywhere in the window settings to ensure they are open.
2 Replies 2
Guru
Given that this is to do with objects, it would be helpful if you would include the name of the object and the version of AC you are using. To streamline things, I would suggest adding your AC version/s and some information about your computer to your forum signature.
Ling.
runxel
That's a Cadimage window, which is now Centralinnovation. Better to ask them directly!
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
