Betencorte
MEP System as a graphic override criteria
Hello, i have a question, is there a way of using the MEP system as a criteria for the graphic override? Looks like a very simple thing to be able to do in archicad, but a cannot see the MEP system as a criteria for the Graphic Override rules.
3 Replies 3
Eduardo Rolon
Try using Classifications
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Betencorte
Well, i am using as a classification system the brazillian ABNT NBR 15965, which does not differentiate what is hot water and what is cold water, and i'm using this classification for the entire project, maybe i'll have to put another one just for that...
So that is the reason why i was questioning the lack of MEP systems as a criteria for the rules in the Graphic Override, why dont graphisoft add the same option of adding library part parameters as it is one of the criteria options when doing schedules?
Eduardo Rolon
Agree, variations of having access to more parameters in Properties is a long time wish.
AC29 US/INT -> AC08
