Minimum Parameters
Is there a place where I can find the Minimum Parameters for an element in the SE 9 Library. It is annoying to me that the parameters used will not meet the "VALID PARAMETERS." I have been trying for a couple of hours to fit a fireplace in the hole it was designated to go in by the manufacturer. I could not get it to fit because of "INVALID PARAMETERS." The feature that tells when it is invalid is good SOMETIMES. But I was pulling the dimensions right off the paperwork from the manufacturer and it was still invalid even though they build them and install them everyday. It now fits and I am greatly relieved and I appreciate the ability to vent on others that can tell me how stupid I am by giving me the answer to my problem but sometimes i guess we all are. Anyway, if there is somewhere i could get a list if these parameters i would greatly appreciate it. Thanx guys. You have relieved my stress and didn't even know it.
11 Replies 11
Peter wrote:
Seiss,
I was thinking about your question and decided that,
in effect, there is a way to get the error to display as soon
as you enter an invalid value in the settings dialog without
having to go to the 3D widow or the section/elevation window
to find out if you have entered an invalid value.
In the settings dialog select the preview to be the 3D view.
Immediately after you enter an invalid value in a parameter,
you will get the error message because the 3D script
has to run to display the 3D preview.
This, of course, does not help in finding out what the "valid" values are.
Peter Devlin
In principle, the GDL script should be written so as to preclude any invalid values. Unfortunately this is not always easy to do.
The fundamental problem with GDL is that the complexity of the programming increases exponentially (hyperbolically? there are probably already some proofs about this) with the number of parameters and variations in the part's functions. That is to say it is much easier to code a specific window than a generic single casement, which is still easier than a generalized multi-unit, etc.
I have seen the greatest success in custom parts when the parameters are very limited (a trestle table for example) or the performance spec is very clearly and strictly defined (as in the case of office standard symbols). Unfortunately custom parts don't work so well for general release.
I've already gone on (and on) about the solutions for this so I won't belabor it here.
Seiss wrote:
PETER -
Why does the script have to be run before the user is notified that he has committed an error?
It is like trying to crank a car. You don't know it won't crank untill you have first turned the key.
